Add a high-powered 1080p IN3138HDa network HD projector to your meeting room or classroom for a price that will fit your tight budget.
You'll get incredible image quality and smooth video playback through its two HDMI ports, including one with MHL compatibility. Easily manage the IN3138HDa over the network and easily install it with AMX and Crestron room control systems.
Digital connectivity
Fully loaded with the latest set of connections. -
Immersive 3D
Enjoyable and comforatble 3D experience in the classroom or office. -
Network support and control
IT managers and tech teams can manage the IN3138HDa HD projector remotely.
- InFocus IN3138HDa Professional Network - DLP projector - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 4500 lumens
- Contrast Ratio
- 20000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1 billion colours
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-H)
- Video Modes
- 480p, 720p, 1080p, 480i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 340 Watt
- 28.5 cm x 26.1 cm x 12.18 cm
- 3.15 kg
- 2-year warranty
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 4500 lumens
- Brightness (Reduced)
- 3200 lumens
- Contrast Ratio
- 20000:1
- Image Size
- 66 cm - 825 cm
- Projection Distance
- 1.2 m - 10 m
- Throw Ratio
- 1.39 - 2.09:1
- Uniformity
- 80 %
- Resolution
- WXGA - Full HD (1920 x 1080)
- 16:9
- Colour Support
- 1 billion colours
- Max Sync Rate (V x H)
- 120 Hz x 90 kHz
- Bulb life cycle
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Portuguese, Russian, Spanish
- 6-segment colour wheel, BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, MHL compliance, 3D Triple Flash technology
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-H
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x network - RJ-45 (management) , 1 x USB - 4 pin mini-USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), security bar
- UL, TUV GS, cUL, PSB, FCC, CU-PCT
- Power Source
- AC
- Voltage Required
- 340 Watt
- Power Consumption Stand by
- 0.5 Watt
- 28.5 cm
- 26.1 cm
- 12.18 cm
- 3.15 kg
- Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 35 dB
