Confidently beam your most important content with the high brightness and quality of the incredibly affordable IN110x series projectors.
These value-packed projectors are built to perform with HDMI input, high brightness, high contrast, and BrilliantColor technology. Plus, their compact design and light weight make them as easy to move around as they are to install.
Lowest total cost of ownership
The IN110x series' lamps can last up to an amazing 10,000 hours. There aren't even any filters to replace. It's an unbeatable value. -
3D ready
The IN110x series supports multiple forms of 3D - including Blu-Ray, 3D broadcasting, video games and PC connectivity. -
Eco Blanking
Instantly dim the screen to divert your audience's attention onto you with the Eco Blanking feature on the remote control. Activate this feature when the projector isn't being used and lower the lamp's power usage down to 30%. This saves energy and significantly extends the life of the lamp, which saves you money. -
High brightness and high contrast
The image quality of this projector will not disappoint. Up to 3200 lumens will give you bright, clear images with the lights on and the 15000:1 contrast ratio adds sharpness with darker blacks and whiter whites. Preset modes give you the best image quality on a beige wall, whiteboard, blackboard or other surface.
- InFocus IN118HDxc - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3200 lumens
- Contrast Ratio
- 15000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 203 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- 29.2 cm x 22 cm x 12.1 cm
- 2.45 kg
- 2-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3200 lumens
- Brightness (Reduced)
- 2900 lumens
- Contrast Ratio
- 15000:1
- Image Size
- 759 cm
- Projection Distance
- 1.2 m - 10 m
- Throw Ratio
- 1.4 - 1.7:1
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91 kHz
- Bulb type
- 203 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Korean, Persian
- 6-segment colour wheel, BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, Eco Blank
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.22x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- RGB
- Video Interfaces
- VGA, HDMI
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B (management) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code, security bar
- UL, cUL, NOM, PCT, SABS, SASO, CB, CCC, PSB, FCC, IRAM, KCC, KC, CECP, EAC
- 29.2 cm
- 22 cm
- 12.1 cm
- 2.45 kg
- Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 30 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
