Quickly protecting your business or personal data, Imation RDX removable hard disk cartridges contain a 2.5-inch hard disk drive that offers all of the advantages of disk-to-disk storage, including high performance and a low-failure rate. The cartridges provide both forward and backward compatibility.
Imation RDX removable hard disk cartridges are compatible and interchangeable with all RDX and RD1000 removable hard disk docks on the market. The removable hard disk media provides complete data protection and helps ensure easy-to-use, reliable, fast and portable storage to small- and medium-sized businesses.
Rugged design
RDX removable hard disk cartridges contain a 2.5-inch hard disk drive in a durable shock protected cartridge design tested to withstand up to a one meter drop. -
Compatibility
Read/write compatible and interchangeable with all RDX and RD1000 removable hard disk docks.
- Imation RDX Hard Disk Cartridges - RDX HDD cartridge x 1 - 1 TB - storage media
- Storage media - RDX HDD cartridge
- Media Included Qty
- 1
- Native Capacity
- 1 TB
- Designed For
- Imation RDX Internal USB 3.0 Docking Station; DataGuard R4, T5R; RDX A8
- RDX HDD cartridge
- 1
Media
- Native Capacity
- 1 TB
- Designed For
- Imation RDX Internal USB 3.0 Docking Station , Imation DataGuard R4, T5R , Imation RDX A8
Imation IMATION RDX 1TB CARTRDIGE
