iiyama XUB2490HS-B1 24" 1920x1080 HDMI IPS Monitor
Quicklinx: BD0RWS00 Mfr#: XUB2490HS-B1
Marketing description is not available.
  • IPS
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • HAS + pivot
    With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
  • Blue light reducer
    As we all know looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows the eyes to feel less tired while working long hours with a computer screen. This product achieves it by adjusting the monitor's brightness and color temperature through a feature called "blue light reduction" easily accessible through the monitor's OSD menu.
  • Overdrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the overdrive feature will eliminate that.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
iiyama ProLite XUB2490HS-B1 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
21.9 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Height, pivot (rotation)
Matte black
54 cm x 23 cm x 36.5 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
VESA DPMS, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class A
32 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Slim bezel design
Matte black
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI-D , HDMI , Audio line-in
Mechanical
Rotation Angle
90
Height Adjustment
130 mm
1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable , 1 x audio cable
21.9 W
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.5 Watt
Sustainability Information
ENERGY STAR Certified
BD0R C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
