ProLite XU2590HS is a 25" LED backlit LCD screen featuring IPS Panel technology which is considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles (178°/178°) and fast response time (5 ms black-to-black). XU2590HS is full HD, has a > 5mln:1 Advanced Contrast Ratio and 250 cd/m2 brightness offering the user a clear and vivid image. The ProLite XU2590HS will provide excellent performance for photographic design, web design, standard office use and in multi-monitor environment. Very suitable for multi-monitor Digtal Signage and office applications.
IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Overdrive ON/OFF
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Speakers
This LED monitor is equipped with two high quality stereo speakers. -
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite XU2590HS-B1 - LED monitor - Full HD (1080p) - 25"
- LED-backlit LCD monitor - 25"
- Energy Class
- Class A
- Energy Consumption per Year
- 37 kWh
- Power Consumption (On mode)
- 25.1 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.288 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 57.75 cm x 18 cm x 40.75 cm
- 4.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC-2B, VESA DPMS, DDC/CI, TUV Bauart, VCCI Class B
- Display Type
- Energy Class
- Class A
- 37 kWh
- Diagonal Size
- 25"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.288 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 76 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control, blue reduction
- OSD Languages
- Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), blue light reduction, i-Style Color
- Black
- 57.75 cm x 18 cm x 40.75 cm - with stand
- 4.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , HDMI , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -4/+20
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Cable management cover
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Input Voltage
- 25.1 W
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8
- Dimensions & Weight Details
- Without stand - width: 57.75 cm - depth: 4.5 cm - height: 33.95 cm , With stand - width: 57.75 cm - depth: 18 cm - height: 40.75 cm - weight: 4.4 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
