iiyama XB2283HS-B5 ProLite 21.5" 1920x1080 HDMI 4MS Black
Quicklinx: G2JPWS00 Mfr#: XB2283HS-B5
The ProLite XB2283HS is an excellent 22" Full HD LED-backlit monitor with 1920x1080 resolution and VA panel technology, guaranteeing accurate and consistent color reproduction with wide viewing angles. Triple input support ensures compatibility with the embedded notebook outputs. The XB2283HS is also equipped with two high-quality stereo speakers and TCO certified. The ergonomic stand offers 13 cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. A perfect solution for education, local government, business and finance markets.
  • Flicker-free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors.
  • OverDrive ON / OFF
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers and headphones
    Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset into the headphone socket and turn the volume up.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • HAS + Pivot
    With a height-adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
iiyama ProLite XB2283HS-B5 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/368721
Energy Class
Class F
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
18.8 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
50.5 cm x 23 cm x 37.15 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
3-year warranty
Display Type
Energy Class
Class F
28 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , HDMI (HDCP) , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
18.8 W
18.8 kWh/1000h
Power Consumption (Typical)
21 Watt
Sustainability Information
ENERGY STAR Certified
3-year warranty
