Specifically developed for touch screens which can be used in the face-up (table) position. This wheeled stand has electrical height adjustment from 660-1320 mm (table height). The Tip & Touch stand is available with a tip function by gas spring or a electrical tip function. Furthermore the head of the stand contains a fixed bracket with most VESA-patterns integrated.
- Iiyama Tip & Touch stand - for LCD display
- Product Type
- Stand
- Adjustable Height
- 66-132 cm
- Recommended Use
- LCD display
- VESA Mounting Interface
- 950 x 590 mm
- Max Load Weight
- 60 kg
- Designed For
- ProLite TF3237MSC-B1AG, TF3238MSC-B1AG, TF4237MSC-B1AG, TF4338MSC-B1AG, TF4637MSC-B1AG, TF5537MSC-B1AG
- Adjustable Height
- 66-132 cm
AV Furniture
- Stand
- Recommended Use
- LCD display
- 950 x 590 mm
- Max Load Weight
- 60 kg
- Wheels, motorised, table function, electric height adjustment
- Designed For
- Iiyama ProLite TF3237MSC-B1AG, TF3238MSC-B1AG, TF4237MSC-B1AG, TF4338MSC-B1AG, TF4637MSC-B1AG, TF5537MSC-B1AG
