iiyama Thin Client Bracket For iiyama BXX83 Range
Quicklinx: 9N4ZWS00 Mfr#: md-brpcv02
MD BRPCV02 is a high quality bracket that allows a mini PC or thin client to be mounted to the iiyama height adjustable stand.
  • Efficient mounting
    Designed specifically for mini PCs, the MD BRPCV02 offers a seamless mounting experience, allowing users to easily attach their devices to monitors for a streamlined workspace.
  • Versatile compatibility
    Featuring a VESA mount bracket with a flat panel mount interface of 100 x 100 mm, this mounting component is compatible with a wide range of monitors, ensuring a secure and stable setup.
Iiyama MD BRPCV02 mounting component - for mini PC - black
Mounting component - monitor
Mounting Components
VESA mount bracket
Recommended Use
Mini PC
VESA Mounting Interface
100 x 100 mm
5-year warranty
ProLite B2083HSD-1, GB2773HS-1, XB2483HSU-1, XB2776QS-1, XB2779QS-1, XB2783HSU-1, XUB2495WSU-B1, XUB2790HS-1
AV Furniture
Mounting component
Mounting Components
VESA mount bracket
Recommended Use
Mini PC
Placing / Mounting
Monitor
100 x 100 mm
Limited warranty - 5 years
Iiyama ProLite B2083HSD-1, GB2773HS-1, XB2483HSU-1, XB2776QS-1, XB2779QS-1, XB2783HSU-1, XUB2495WSU-B1, XUB2790HS-1
