iiyama TF4338MSC-B2AG 43" 1920x1080 12ms VGA DVI HDMI DisplayPort Touch IPS LED Large Format Display
Quicklinx: FJ3HWS00 Mfr#: TF4338MSC-B2AG
The Full HD TF4338MSC is the ideal interactive display solution for education, kiosks, interactive digital signage and in-store communications. The PCAP touch technology with 12 touch points ensures a seamless and accurate touch response. Featuring a metal housing, scratch-resistant, edge-to-edge glass and an IPS panel; this display can be used in landscape, portrait and face-up orientation in demanding environments for maximum flexibility and accessibility.
  • Enhanced interactivity
    Equipped with projected capacitive technology, the iiyama ProLite TF4338MSC-B2AG offers a responsive 12-point multi-touch experience, allowing for seamless interaction and engagement. Its palm rejection function ensures accuracy and comfort during use, making it ideal for interactive kiosks and displays.
  • Superior visibility
    This monitor features a 43-inch LED-backlit LCD display with Full HD 1080p resolution, providing clear and vivid images. The edge-to-edge glass and anti-glare coating enhance visibility in various lighting conditions, while the 450 cd/m2 brightness and 1100:1 contrast ratio deliver deep blacks and bright whites.
  • Versatile connectivity
    With a comprehensive range of interfaces including HDMI, DisplayPort, VGA, and DVI, the iiyama ProLite TF4338MSC-B2AG ensures compatibility with a wide array of devices. Additional connectivity options such as audio line-in/out, network, RS-232C, and IR in/out ports offer flexibility for various multimedia setups.
  • Durable and reliable
    Designed for durability, the monitor boasts a 7H Hard Coating to protect against scratches and damage. It also meets IP54 standards for dust and water resistance, making it suitable for use in challenging environments. The inclusion of a Kensington security slot provides added security against theft.
iiyama ProLite TF4338MSC-B2AG - LED monitor - Full HD (1080p) - 43"
LED-backlit LCD monitor - 43" - touchscreen
Energy Class
Class A
Energy Consumption per Year
97 kWh
Power Consumption (On mode)
66 W
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.4902 mm
Brightness
450 cd/m²
Contrast Ratio
1100:1
Response Time
12 ms
Colour Support
16.7 million colours (6-bit)
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Screen Coating
7H Hard Coating
Voltage
987.5 mm x 68 mm x 587.7 mm
21.6 kg
CB, cULus, REACH, IP54, TUV Bauart, EAC, VESA DDC 2 B
3-year warranty
Display Type
Energy Class
Class A
97 kWh
Diagonal Size
43"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.4902 mm
Brightness
450 cd/m²
Brightness w/touchscreen
380 cd/m²
Contrast Ratio
1100:1
Colour Support
Response Time
12 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Anti-glare, High Frame Rate Control (Hi-FRC), edge-to-edge glass, OSD lock, HID Compliant, Projected Capacitive Touch (P-CAP) technology, landscape mode, portrait mode, Face Up mode, palm rejection function, kiosk mode
21.6 kg
Audio
Speakers - stereo
Output Power / Channel
8 watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI , 2 x HDMI , DisplayPort , Audio line-out , Audio line-in , Network , RS-232C , IR in/out
Mechanical
VESA Mounting Interface
400 x 200 mm
Security lock slot (cable lock sold separately), IP54 protection, HDCP Compliant, 84% light transmittance
Remote control
1 x USB cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x IR extender cable
Security Slot Type
Input Voltage
66 W
Power Consumption (Typical)
75 watt
Power Consumption Stand by
1 watt
Power Consumption (Off Mode)
1 watt
On / Off Switch
Linux, Microsoft Windows
Limited warranty - 3 years
