The Full HD (1920 x 1080) Open Frame TF3238MSC is the ideal interactive display solution for education, kiosks, interactive Digital Signage and in-store communications. It can be installed in landscape, portrait and face-up orientation for maximum flexibility and accessibility. The Projective Capacitive (PCAP) touch technology with 12 touch points ensures a seamless and accurate touch response. With its AMVA3 LED panel, it offers exceptional color performance, high contrast and wide viewing angles. Featuring a metal housing with a 60950-1 ball-drop proof, scratch-resistant, edge-to-edge glass, this display can be installed in the most demanding environments and build in different set-ups as a result of its Open Frame side mounting holes.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen. -
Touch through-glass
This through glass touch screen works right through glass and can turn glass surfaces into an interactive touch screen display. Use it on storefront windows, real estate office, in-store for POS or restaurants.
- iiyama ProLite TF3238MSC-B2AG 32" Class (31.5" viewable) LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), HDMI, DisplayPort
- Technology
- AMVA3
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 60 watt
- Power Consumption (On mode)
- 56 W
- Energy Consumption per Year
- 81 kWh
- Dimensions (WxDxH) - without stand
- 74.85 cm x 6.8 cm x 45 cm
- 14.5 kg
- Product Type
- Energy Class
- Class B
- 60 watt
- 56 W
- 81 kWh
- Diagonal Class
- 32"
- Diagonal Size
- 31.5"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Portrait mode, landscape mode, Face-up Mode
- Protection
- Super-clear anti-glare screen
- Dimensions
- Without stand
- 74.85 cm
- 6.8 cm
- 45 cm
- 14.5 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- 7H Hard
- Image Contrast Ratio
- 3000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 160 degrees
- Viewing Angle (Vertical)
- 150 degrees
- Touchpoints Qty
- 12
- Response Time
- 8 ms
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- 3M Projected Capacitive Technology (PCAP)
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- VGA input , DisplayPort input , 2 x HDMI , USB , Audio line-out , Audio line-in , DVI-HDCP
- Remote control
- Cables Included
- DisplayPort cable , USB cable , HDMI cable , IR extender cable
- DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart, CU
- Power Device
- Power supply
- Input Voltage
- On / Off Switch
- 0 °C
- 40 °C
