iiyama T5561UHSC-B1 55" 3840x2160 VGA DVI HDMI DisplayPort Touchscreen LED Large Format Display
Quicklinx: FJ3KWS00 Mfr#: T5561UHSC-B1
The 4K UHD (3840 x 2160) T5561UHSC is the ideal interactive display solution for education, interactive Digital Signage and in-store communications. The Projective Capacitive (PCAP) touch technology with 40 touch points ensures a seamless and accurate touch response.
Featuring scratch-resistant metal housing with 60950-1 ball-drop proof, edge-to-edge glass and an IPS panel; this display can be used in landscape and portrait orientation in the most demanding environments for maximum flexibility and accessibility. This through glass touch screen has capacity to work through glass and can turn glass surfaces into an interactive touch screen display. Use it on storefront windows, real estate office, in-store for POS or restaurants.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • Touch through-glass
    This through glass touch screen works right through glass and can turn glass surfaces into an interactive touch screen display. Use it on storefront windows, real estate office, in-store for POS or restaurants.
iiyama ProLite T5561UHSC-B1 55" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display with touchscreen (multi touch) / optional slot-in PC capability
Diagonal Class
55"
Commercial Use
Yes - digital signage
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Voltage
Energy Class
Class C
110 Watt
Power Consumption (On mode)
164 W
Power Consumption Stand by
2 Watt
Energy Consumption per Year
240 kWh
124.75 cm x 8.1 cm x 73.25 cm
30.7 kg
3-year warranty
Energy Class
Class C
110 Watt
164 W
240 kWh
Diagonal Class
55"
Commercial Use
Combined With
Touchscreen (multi touch) / optional slot-in PC capability
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Protection
Fingerprint-proof
124.75 cm
8.1 cm
73.25 cm
30.7 kg
Enclosure Colour
Matte black
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
6H Hard
Image Contrast Ratio
1100:1
Brightness
420 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
40
Response Time
6 ms
Display Menu Language
English, German, French, Italian, Spanish, Japanese, Chinese
Open Pluggable Specification slot, Projected Capacitive Touch (PCT), edge-to-edge glass, anti-fingerprint, touch through-glass (6mm, 2 points touch)
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
Media Player
USB Port
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x speaker - 8 Watt
Connector Type
DisplayPort input , 2 x HDMI , DVI-I input , Audio input , Audio line-out , USB
DVI-I to VGA cable , HDMI cable , USB cable , Audio cable
Plug and Play, DDC-2B, CB, EAC, REACH SvHC
Power supply
Input Voltage
2 Watt
Limited warranty - 3 years
