ProLite T1931SR-1 is based on the 5 Wire Resistive technology. Price/performance ratio is ideal for the budget conscious user while quality and specification is certainly not compromised. The display inputs include both analog and digital (DVI) with touchscreen connectivity via either USB or RS-232 which offers greater than typical flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90-degree angles. Extensive touch utilities allow for 4-point calibration and either 9/25 point linearization.
Touch technology
5-wire resistive touchscreens are very durable and can be used in a variety of environments. They are especially recommended for shops, restaurants and industrial purposes. -
Cable management system
Comfortable and elegant - thanks to the cable management system you can easily hide the cables at the back of the monitor cabinet. -
RS-232 and USB connectivity
For greater flexibility this monitor supports touchscreen connectivity with either USB or RS-232 interfaces. -
IP54
The IP code classifies how resistant a device is to foreign objects and moisture. IP54 means that the monitor will operate in dusty conditions, and will resist splashing water.
- iiyama ProLite T1931SR-B1 - LCD monitor - 19"
- LCD monitor - 19" - touchscreen
- Touch-screen, stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 900:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 43.1 cm x 39.1 cm x 21.8 cm
- 6.5 kg
- Plug and Play, FCC Class B certified, UL, TUV, VCCI Class B ITE, cUL
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 19"
- Built-in Devices
- Stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 900:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- +85 / -80
- Vertical Viewing Angle
- +85 / -80
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock
- OSD Languages
- English, German, French, Italian, Spanish, Japanese, Chinese
- Black
- 6.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Resistive
- Serial , DVI-D , VGA , Audio line-in , USB
Mechanical
- Tilt
- Tilt Angle
- 95
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x serial cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by / Sleep
- 2 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Apple MacOS, Microsoft Windows 95/98/ME/2000/XP
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
