iiyama T1731SR-B1S 17" 1280x1024 5ms VGA HDMI DP Touch LCD Monitor
Quicklinx: HGCTWS00 Mfr#: T1731SR-B1S
£280.83 ex VAT
£336.99 inc VAT
Express delivery Order within the next 0 minutes for delivery tomorrow
Discover the iiyama ProLite T1731SR-B1S, a 17-inch LED-backlit LCD monitor that combines superior display technology with interactive touchscreen capabilities. Designed for professional and personal use, this monitor features a 1280 x 1024 native resolution, offering vivid and clear visuals across its 17-inch screen. With resistive touchscreen technology, it supports both finger and glove touch modes, making it versatile for various applications.
The iiyama ProLite T1731SR-B1S ensures seamless connectivity, equipped with HDMI, VGA, and DisplayPort interfaces, along with an included USB cable for touch functionality. This allows for easy integration with a wide range of devices. Its raised bezel and IP54-rated front provide durability against dust and water, while the Kensington security slot offers added protection against theft. Moreover, this monitor is an eco-friendly choice, featuring an efficient design that minimizes power consumption without compromising performance. Embrace the blend of technology and interactivity with the iiyama ProLite T1731SR-B1S.
iiyama ProLite T1731SR-B1S - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Energy Class
Class E
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
Black, matte
38.7 cm x 23.95 cm x 37.8 cm
5.4 kg
Plug and Play, EAC, RoHS, ERP, WEEE, cULus, VCCI, REACH, UKCA, IP54 front, REACH SvHC
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Brightness w/touchscreen
200 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Refresh Rate
31.5 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, OSD key lock, finger touch mode, glove touch mode
Black, matte
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
VGA , HDMI , DisplayPort , USB , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 80% light transmittance
1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable
Security Slot Type
Input Voltage
13 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
1.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows, Linux
Limited warranty - 3 years - on-site
Brand: iiyama
Stock Status: While stocks last
Stock Status: Clearance
