iiyama Single Screen Desk Top Mounting Arm
Quicklinx: D1BLWS00 Mfr#: DS1001C-B1
Accessory Type: Mount
Hurry, only 3 left in stock!
£24.51 ex VAT
£29.41 inc VAT
Sleek and stylish single gas spring arm
The iiyama DS3001C-B1 is a desk mount (grommet or clamp) for flat screens up to 27". Using the arm guarantees you gain additional space on your desk and the cable management system helps to keep the workplace tidy. But more importantly, offering broad adjustment capabilities including tilt, swivel, height and rotation, he arm makes sure you can easily adjust the screen position to your preferences assuring ergonomic body posture.
  • Flexible positioning
    With an adjustable arm that lifts up to 20 cm, pans 180°, and rotates 90°, this mounting kit offers flexibility in positioning your monitor for the perfect viewing angle.
  • Ergonomic design
    The DS1001C-B1 features a tilt range from -85° to 15°, allowing users to adjust their monitor to an ergonomic position, reducing neck and eye strain during long working hours.
  • Seamless cable management
    Integrated cable management keeps your workspace tidy and free from cable clutter, enhancing your work efficiency and maintaining a clean aesthetic.
  • Versatile compatibility
    Supporting flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm, and a maximum load weight of 10 kg, this mounting kit is compatible with a wide range of monitors, from 10" to 30" in size.
Iiyama DS1001C-B1 mounting kit - adjustable arm - for Monitor - black
Mounting kit (adjustable arm) - desk-mountable
Tilt
-85° to 15°
Pan
180°
Lift
20 cm
Rotation
90°
Recommended Use
Monitor
Recommended Display Size
10"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
5-year warranty
ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
Monitor
Placing / Mounting
Desk-mountable
Cable Management
10"-30"
Tilt
-85° to 15°
Pan
180°
Lift
20 cm
Rotation
90°
Max Load Weight
10 kg
Limited warranty - 5 years
Iiyama ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
Brand: iiyama
