Convenient design
The remote control features an ergonomic design that fits comfortably in the user's hand, making it easy to operate from a distance. -
Broad device support
It is compatible with a range of monitor devices, allowing users to control multiple monitors effortlessly.
 - iiyama remote control
 - Remote control
- Supported Devices
 - Monitor
- Designed For
 - ProLite TH6567MIS-B1AG, TH7067MIS-B1AG, TH7067MIS-B2AG
 - Remote control
- Supported Devices
 - Monitor
- Designed For
 - Iiyama ProLite TH6567MIS-B1AG, TH7067MIS-B1AG, TH7067MIS-B2AG
