ProLite XUB2390HS is a 23" LED monitor with latest IPS Panel technology considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles and a fast response time. A truly ergonomic stand including pivot function makes the XUB2390HS an excellent choice for photographic design, web design, standard office use. It’s the perfect choice for multi-monitor applications.
- iiyama ProLite XUB2390HS-B1 - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 22 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Colour Support
- 16.8 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Swivel, tilt
- Black
- 53.25 cm x 23 cm x 38.6 cm
- 5.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- PSE Mark, Green Mark, J-MOSS, TUV Bauart, VCCI Class B
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 32 kWh
- Diagonal Size
- 23"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- WLED
- HDCP, Eco-Mode, Overdrive technology, anti-glare, Advanced Contrast Ratio (ACR)
- Black
- 53.25 cm x 23 cm x 38.6 cm - with stand
- 5.4 kg
Audio
- Speakers - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , Audio line-in
Mechanical
- Swivel, tilt
- Tilt Angle
- -4/+20
- Swivel Angle
- 90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D - 1.8 m , 1 x audio cable - 1.8 m
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 22 W
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Windows 8
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 1 year , Limited warranty - LCD panel - 1 year
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £20.51 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £53.35 |
