iiyama ProLiteXUB2390HS-B1 23" 1920x1080 5ms VGA DVI-D HDMI LED IPS Monitor
Quicklinx: B1DTWS00 Mfr#: XUB2390HS-B1
ProLite XUB2390HS is a 23" LED monitor with latest IPS Panel technology considered to be the best all round panel type. It offers accurate and consistent color reproduction with wide viewing angles and a fast response time. A truly ergonomic stand including pivot function makes the XUB2390HS an excellent choice for photographic design, web design, standard office use. It’s the perfect choice for multi-monitor applications.
  • Wide viewing angles
    Equipped with AH-IPS technology, this monitor offers +89 / -89 degrees horizontal and vertical viewing angles, ensuring vivid and consistent colors from all viewing positions.
  • Ergonomic design
    With swivel and tilt adjustments, users can easily find their optimal viewing position, enhancing comfort during extended use.
  • High dynamic contrast
    The dynamic contrast ratio of 5000000:1 delivers deeper blacks and brighter whites, providing a more immersive viewing experience for all types of content.
  • Energy efficient
    ENERGY STAR certification and a power consumption of just 16.3 W in on mode make this monitor an eco-friendly choice for energy-conscious users.
  • Versatile connectivity
    Featuring HDMI, DVI-D, and VGA interfaces, this monitor offers flexible connectivity options for both modern and legacy devices.
iiyama ProLite XUB2390HS-B1 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/356022
Energy Class
Class E
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
16.3 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Swivel, tilt
Voltage
53.25 cm x 23 cm x 38.6 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
PSE Mark, Green Mark, J-MOSS, TUV Bauart, VCCI Class B
3-year warranty
Display Type
Energy Class
Class E
32 kWh
Diagonal Size
23"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
WLED
HDCP, Eco-Mode, Overdrive technology, anti-glare, Advanced Contrast Ratio (ACR)
53.25 cm x 23 cm x 38.6 cm - with stand
5.4 kg
Audio
Speakers - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in
Mechanical
Swivel, tilt
Tilt Angle
-4/+20
Swivel Angle
90
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D - 1.8 m , 1 x audio cable - 1.8 m
Power Supply
Internal
Input Voltage
16.3 W
16.3 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
Windows 8
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 1 year , Limited warranty - LCD panel - 1 year
5 °C
35 °C
10 - 80% (non-condensing)
