iiyama ProLite XUB2792QSU-W1 27" 2560x1440 5ms HDMI DVI DP LED Monitor
Quicklinx: DQSQWS00 Mfr#: XUB2792QSU-W1
Stylish ultra-flat front design makes the ProLite XUB2792QSU perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles and the WQHD resolution means the XUB2792QSU can accommodate more information on the screen than a Full HD display. High contrast and brightness values guarantee the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor digital signage and office applications.
iiyama ProLite XUB2792QSU-W1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/360740
Energy Class
Class G
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
29.7 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 70 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Screen Coating
Matte
Voltage
White
61.1 cm x 23 cm x 39.7 cm
6.1 kg
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, CU
3-year warranty
Display Type
Energy Class
Class G
50 kWh
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 89 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color
White
6.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI , HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable
Input Voltage
29.7 W
29.7 kWh/1000h
Power Consumption (Typical)
33 Watt
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
