Stylish edge-to-edge design makes the ProLite XUB2493HS perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High-contrast and brightness values mean the monitor will provide excellent performance for photographic and web design. Equipped with speakers, headphone socket, HDMI and DisplayPort connections, a blue light reducer function to reduce eye fatigue and an ergonomic 150mm height adjustable stand for optimal user comfort, make this 24'' monitor a great choice for both multi-monitor configuration and office applications.
IPS technology
IPS displays are best known for wide viewing angles and natural, highly accurate colors. They are especially suited for color-critical applications. -
Eye-saving functions
The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors. -
High-quality speakers
Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset into the headphone socket and turn the volume up. -
Advanced contrast ratio
Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite XUB2493HS-B5 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class D
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Matte
- Voltage
- AC 100-240 V (50/60 Hz)
- Matte black
- 53.95 cm x 20.95 cm x 34.3 cm
- 5.7 kg
- Environmental Standards
- TCO Certified Displays 9
- DDC-2B, DDC/CI, RoHS, WEEE, PSE Mark, REACH, TUV Bauart, ERP, VCCI Class B, EAC, UKCA
- 3-year warranty
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, i-Style Color, Adaptive-Sync technology, 3 Side Borderless Design, Blue Light Reducer Function
- Matte black
- 5.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI , DisplayPort , Headphones
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Cables Included
- 1 x HDMI cable , 1 x power cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 14 kWh/1000h
- Power Consumption (Typical)
- 15 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- OS Required
- Apple MacOS X
- Shipping Width
- 63.5 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 39 cm
- Shipping Weight
- 6.4 kg
Sustainability Information
- TCO Certified
- Limited warranty - 3 years - on-site
