iiyama ProLite XUB2492HSU-W1 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FJ0RWS00 Mfr#: XUB2492HSU-W1
Stylish edge-to-edge design makes the ProLite XUB2492HSU perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles. High contrast and brightness values mean the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor digital signage and office applications.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Height adjustable stand
    With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
  • Flicker-free
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
  • Excellent speakers
    This LED monitor is equipped with two high -quality stereo speakers.
iiyama ProLite XUB2492HSU-W1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/446381
Energy Class
Class E
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
16.2 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V (50 - 60 Hz)
White
53.95 cm x 23 cm x 37.6 cm
5.4 kg
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
3-year warranty
Display Type
Energy Class
Class E
26 kWh
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Estonian, Japanese, Chinese
Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, i-Style Color, Blue Light Filter technology
White
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI (HDCP) , VGA , DisplayPort , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable
Input Voltage
16.2 W
16.2 kWh/1000h
Power Consumption (Typical)
16 Watt
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
