iiyama ProLite XUB2395WSU-B1 23" 1920x1200 4ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FJ0QWS00 Mfr#: XUB2395WSU-B1
Diagonal Size: 22.5in
Max Resolution: 1920 x 1200
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£133.33 ex VAT
£159.99 inc VAT
The demanding data and application heavy world needs a display that creates a more productive work place. The height adjustable stand with pivot function allows you to easily adjust the monitor position to your preferences and the IPS panel technology assures accurate and consistent color reproduction with wide viewing angles.
  • Enhanced connectivity
    Equipped with HDMI, VGA, and DisplayPort interfaces, the iiyama ProLite XUB2395WSU-B1 ensures versatile connectivity options for seamless integration into any workspace. The built-in USB 2.0 hub further enhances its functionality, allowing for easy connection of peripheral devices.
  • Optimal viewing experience
    Featuring AMD FreeSync technology and a dynamic contrast ratio of 5000000:1, this monitor delivers smooth, tear-free visuals and deep blacks for a more immersive viewing experience. The IPS technology ensures accurate color reproduction and wide viewing angles, making it suitable for both professional and leisure activities.
  • Ergonomic design
    With height, pivot, swivel, and tilt adjustments, the iiyama ProLite XUB2395WSU-B1 offers an ergonomic design that can be tailored to any user's needs, enhancing comfort during long working hours. The monitor's ultraslim design and matte display screen coating also minimize glare and reduce eye strain.
  • Advanced visual features
    This LED-backlit LCD monitor boasts a 1920 x 1200 native resolution, providing crisp and clear images. The inclusion of Blue Light Filter and Flicker-Free technology further protects users' eyes from fatigue, making it suitable for extended use.
  • Energy efficient
    Certified by ENERGY STAR and TCO certified Displays 7, the iiyama ProLite XUB2395WSU-B1 is not only environmentally friendly but also energy-efficient, with a power consumption of just 17.4 W in on mode. This makes it an ideal choice for eco-conscious consumers looking to reduce their energy usage.
iiyama ProLite XUB2395WSU-B1 - LED monitor - 22.5"
LED-backlit LCD monitor - 22.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/356024
Energy Class
Class E
Power Consumption (On mode)
17.4 W
Adaptive-Sync Technology
AMD FreeSync
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Matte
Voltage
49.9 cm x 23 cm x 38.5 cm
5.4 kg
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified
RoHS, WEEE, TUV Bauart
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
22.5"
AMD FreeSync
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 89 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
English, German, French, Polish, Russian, Dutch, Japanese
Ultra Slim Design, HDCP, Flicker Free technology, Blue Light Filter technology
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI (HDCP) , DisplayPort , 2 x USB 2.0 , Headphone input
Mechanical
Tilt Angle
-4/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x USB cable , 1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
17.4 W
17.4 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years - on-site
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
