The ProLite XB3288UHSU-B1 is a monitor capable of displaying 4 times more information than a Full HD screen. It will hence suit a massive range of applications requiring an above average viewable area, like desktop publishing, CAD/CAM drawing, data virtualization, photographic and web design. The VA panel technology offers exceptional color performance, high contrast and wide viewing angles.
- iiyama ProLite XB3288UHSU-B1 - LED monitor - 4K - 32" - HDR
- LED-backlit LCD monitor - 32"
- Energy Class
- Class G
- Energy Consumption per Year
- 65 kWh
- Power Consumption (On mode)
- 39.9 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.181 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- Response Time
- 3 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 95% NTSC
- Input Connectors
- 2xHDMI, DisplayPort
- Height, swivel, tilt
- Screen Coating
- Matte
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 73 cm x 23 cm x 45.85 cm
- 8.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC/CI, PSE Mark, REACH, TUV Bauart, VCCI Class B, CU, DisplayPort 1.2, REACH SvHC
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 65 kWh
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.181 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 95% NTSC
- Response Time
- 3 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 135 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese
- Picture by picture, HDCP, Eco-Mode, 10-bit gamma, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, i-Style Color, Picture-in-Picture
- Matte black
- 73 cm x 23 cm x 45.85 cm - with stand
- 8.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- 2 x HDMI (HDCP) , DisplayPort 1.2 , USB 3.0 upstream (Type B) , USB 3.0 downstream (Type A) , Headphones (mini-jack) , USB 3.0 downstream with Power Charging (Type A)
Mechanical
- Tilt Angle
- -3/+22
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable ¦ 1 x DisplayPort cable ¦ 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 39.9 W
- Power Consumption SDR (On mode)
- 39.9 kWh/1000h
- Power Consumption HDR (On mode)
- 52.1 kWh/1000h
- Power Consumption (Typical)
- 44 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- 3-year warranty
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
