The ProLite XB3288UHSU-B1 is a monitor capable of displaying 4 times more information than a Full HD screen. It will hence suit a massive range of applications requiring an above average viewable area, like desktop publishing, CAD/CAM drawing, data virtualization, photographic and web design. The VA panel technology offers exceptional color performance, high contrast and wide viewing angles.
                Stunning visualsExperience breathtaking clarity with a 32-inch 4K UHD resolution, supported by a dynamic contrast ratio of 80,000,000:1 and a color gamut of 95% NTSC, delivering vivid, lifelike colors and deep blacks. The LED backlight enhances image brightness and clarity, making every detail pop.
                Ergonomic designDesigned with your comfort in mind, the iiyama ProLite XB3288UHSU-B1 offers extensive display position adjustments including height, swivel, and tilt, ensuring you can find the perfect viewing angle for long hours of use without strain.
                Seamless connectivityEquipped with multiple input options including 2x HDMI, DisplayPort, and a built-in USB 3.0 hub, this monitor provides flexible connectivity options for all your devices, ensuring a seamless user experience whether you're working, gaming, or enjoying multimedia content.
                Advanced features for professionalsWith features like AMD FreeSync, Flicker-Free technology, and blue light reduction, this monitor is designed to enhance your viewing experience, reduce eye strain, and keep you comfortable during extended use. The Picture-in-Picture and Picture-by-Picture modes offer additional productivity for multitasking environments.
- iiyama ProLite XB3288UHSU-B1 - LED monitor - 4K - 32" - HDR
- LED-backlit LCD monitor - 32"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/401986
- Energy Class
- Class G
- Energy Consumption per Year
- 65 kWh
- Power Consumption (On mode)
- 39.9 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.181 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- Response Time
- 3 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 95% NTSC
- Input Connectors
- 2xHDMI, DisplayPort
- Height, swivel, tilt
- Screen Coating
- Matte
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 73 cm x 23 cm x 45.85 cm
- 8.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC/CI, PSE Mark, REACH, TUV Bauart, VCCI Class B, CU, DisplayPort 1.2, REACH SvHC
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 65 kWh
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.181 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 95% NTSC
- Response Time
- 3 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 135 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Dutch, Japanese
- Picture by picture, HDCP, Eco-Mode, 10-bit gamma, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, i-Style Color, Picture-in-Picture
- Matte black
- 73 cm x 23 cm x 45.85 cm - with stand
- 8.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- 2 x HDMI (HDCP) , DisplayPort 1.2 , USB 3.0 upstream (Type B) , USB 3.0 downstream (Type A) , Headphones (mini-jack) , USB 3.0 downstream with Power Charging (Type A)
Mechanical
- Tilt Angle
- -3/+22
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 39.9 W
- Power Consumption SDR (On mode)
- 39.9 kWh/1000h
- Power Consumption HDR (On mode)
- 52.1 kWh/1000h
- Power Consumption (Typical)
- 44 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- 3-year warranty
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
