ProLite X2483HSU-B2 - a 24" LED backlit LCD screen featuring AMVA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Offering great performance for displaying black and white with optimal Native Contrast Ratio, means that the Prolite X2483HSU-B2 will provide excellent performance for photography, design and web design. With the added support of a low power LED panel, the Iiyama Prolite X2483HSU-B2 is also an excellent choice for universities, corporate and financial markets.
Flicker Free technology + blue light reduction
The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced. -
AMVA
AMVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Overdrive on / off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the Overdrive feature will eliminate that. -
ACR
Advanced Contrast Ratio automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen.
- iiyama ProLite X2483HSU-B2 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- USB 2.0 hub
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.25 cm x 20.3 cm x 40.65 cm
- 3.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, CU
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
- Black
- 3.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , HDMI , 2 x USB 2.0 downstream , USB 2.0 upstream , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
- Input Voltage
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8 / 10
Sustainability Information
- ENERGY STAR Certified
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
