iiyama Prolite X2481HS-B 24" 1920x1080 VGA HDMI DVI LED Monitor
Quicklinx: CC1YWS00 Mfr#: XB2483HSU-B2DP
ProLite XB2483HSU-B2DP - a 24" LED backlit LCD screen featuring AMVA panel technology, delivers accurate and consistent color reproduction with wide viewing angles. Offering 24 bit 'True Color' and great performance for displaying black and white with the 3000:1 Native Contrast Ratio, means that the Prolite XB2483HSU-B2DP will provide excellent performance for photographic, design and web-design. The monitor features a height adjustable stand with PIVOT function making it also an excellent choice for universities, corporate and financial markets.
  • HAS + PIVOT
    With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
  • AMVA
    AMVA technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Flicker free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
  • Overdrive on / off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite XB2483HSU-B2DP - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
55.25 cm x 23 cm x 38.1 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, DDC/CI, PSE Mark, VCCI Class B, CU
Display Type
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology
55.25 cm x 23 cm x 38.1 cm - with stand
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , DisplayPort , Headphones (mini-jack) , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , Audio line-in (mini-jack)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable , 1 x DisplayPort cable
Input Voltage
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8/10
Dimensions & Weight Details
Without stand - width: 55.25 cm - depth: 5.65 cm - height: 33.4 cm , With stand - width: 55.25 cm - depth: 23 cm - height: 38.1 cm - weight: 5.6 kg
Sustainability Information
ENERGY STAR Certified
