iiyama Prolite TH7067MIS-B2AG 70" DVI VGA HDMI Anti-Glare Display
Quicklinx: CB0RWS00 Mfr#: TH7067MIS-B2AG
Select:
  • 70"
  • 1080p
Enjoy this 10-point touchscreen, allowing users to make annotations on files opened directly from a USB device or internal storage. The display supports also playback of presentations, video and almost any other type of content, stored on the USB device or internal memory. The high-quality commercial LCD screen ensures great viewing angles from all sides and delivers superb image performance from anywhere in a class or meeting room. The anti-glare screen drastically reduces ambient reflection in high brightness environments without compromising sharp clarity of the content. There are no shadows or reductions in image performance to contend with. The screen is a perfect solution for educational and corporate use.
  • Infrared touch technology
    The infrared technology uses infrared backlight. A touch event is registered with great accuracy, when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality.
  • AG coating
    The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources, affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
  • USB playback
    The monitor supports playback of presentations, video and almost any type of content, stored on the USB device or internal memory.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high-definition images. This means, you can accommodate more information on your screen.
iiyama ProLite TH7067MIS-B2AG 70" Class (69.5" viewable) LED-backlit LCD display - Full HD - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
70"
Diagonal Size
69.5"
Commercial Use
Yes - interactive
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, VGA (HD-15), Mobile High-Definition Link (MHL)
UV²A
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
2 ports
Remote control, stylus, sticker
Voltage
AC 100/240 V (50/60 Hz)
Energy Class
Class B
166.65 Watt
Power Consumption (On mode)
194 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
283 kWh
163.8 cm x 9.75 cm x 96.45 cm
50.5 kg
Energy Class
Class B
166.65 Watt
194 W
283 kWh
Diagonal Class
70"
Diagonal Size
69.5"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
Modes
Portrait mode, landscape mode
Design
Fanless Design
Dimensions
Without stand
163.8 cm
9.75 cm
96.45 cm
50.5 kg
Enclosure Colour
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Coating
Anti-glare
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Touchpoints Qty
10
Response Time
5 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
3 x VGA input , DVI-D input , 3 x HDMI input , USB , USB 2.0 , Composite video/audio input , 3 x audio input , LAN , Serial input , VGA output , USB 3.0 , Digital audio output (coaxial)
Stylus, sticker
VGA cable , DVI cable , USB cable
Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart, CU
Power supply
Input Voltage
0.5 Watt
On / Off Switch
0 - 85% (non-condensing)
