ProLite TH4265MIS-B1AG is a 42" Full HD, professional and fan-less LED-backlit display. Incorporating the InfraRed 20 point touch feature along with the supreme AMVA3 panel color performance, this display offers the optimum performance for a truly multi-user interactive display experience. The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. Besides, it features an ambient light sensor delivering exceptional performance with the added benefit of saving on power. Landscape and Portrait friendly, the display can be mounted according to the application for true impact in Interactive Digital Signage and with Protection Glass the display can handle harshest environments from the Classroom to Public Domain Retail installation.
AMVA3
AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Touch technology - infrared
The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality. -
DisplayPort/HDMI daisy chain support
A daisy chain is a wiring scheme in which multiple devices are wired together in sequence or in a ring. It enables a connection of a series of devices using a single connection between each two devices, using DisplayPort/HDMI input and a DisplayPort/HDMI output. The output connects to the next downstream display. This cabling arrangement, with one DisplayPort/HDMI cable between each set of monitors, provides a simple, less cluttered system configuration. -
USB playback
The monitor supports playback of presentations, video and almost any type of content stored on the USB device or internal memory. -
AG coating
The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
- iiyama ProLite TH4265MIS-B1AG 42" LED display
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Technology
- AMVA3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 2 ports
- Remote Control
- Standard remote
- Voltage
- AC 100 - 240 V (50/60 Hz)
- Energy Class
- Class B
- 75 Watt
- Power Consumption (On mode)
- 75.3 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 110 kWh
- 98.7 cm x 7.45 cm x 57.8 cm
- 24.6 kg
- Product Type
- Energy Class
- Class B
- 75 Watt
- 75.3 W
- 110 kWh
- Diagonal Class
- 42"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Modes
- Portrait mode, landscape mode
- Protection
- Protection glass
- Cooling System
- Fanless
- 98.7 cm
- 7.45 cm
- 57.8 cm
- 24.6 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMVA3
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- LED backlight
- Coating
- Anti-glare, 7H Hard
- Image Contrast Ratio
- 3000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 20
- Response Time
- 6.5 ms
- Display Menu Language
- Czech, English, German, French, Italian, Russian, Spanish, Dutch, Japanese
- Multitouch, infrared multitouch technology, Daisy Chain
Stands & Mounts
- VESA Mounting Interface
- 400 x 400 mm
Media Player
- Supported Video Formats
- MPEG-4, Xvid, DivX, ASF, AVI, MKV, MOV, FLV, RM, 3GPP, F4V, MPG, MPEG
- Supported Audio Formats
- MP3, WMA, WAV, MP4, MKA
- Supported Pictures Formats
- BMP, PNG, JPEG
- USB Port
- USB Ports Qty
- 2
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - built-in - 10 Watt
- Connector Type
- VGA input , 3 x HDMI input , Component video input , HDMI output , USB , Composite video input , Component video output , Audio input , Audio input , Audio output , 2 x USB 2.0 , Serial output , Serial input , LAN , Remote control input , Remote control output
- Included Accessories
- Cable ties, batteries, 3 x touch pens, logo sticker
- Cables Included
- VGA cable , HDMI cable , USB cable
- DDC-2B, VESA DPMS, CB, TUV Bauart, CU
- Power Device
- Power supply
- Nominal Voltage
- 0.5 Watt
- 0 °C
- 40 °C
- 0 - 85% (non-condensing)
