Incorporating the InfraRed 10 point touch feature along with supreme panel color performance, this display offers the optimum performance for a truly multi-user interactive display experience. The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. Features include PIP and PBP perfect for Video Conferencing or handing multi-input content in many environments.
Touch technology - infrared
The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality. -
IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
AG coating
The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. -
PIP
PIP (Picture in Picture) function allows you to watch images coming from two different sources at the same time. -
Light sensor
The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light.
- iiyama ProLite TH4264MIS-B2AG 42" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, pen stylus
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 120 Watt
- Power Consumption Stand by
- 0.5 Watt
- 99 cm x 12.2 cm x 58.45 cm
- 23.6 kg
- Product Type
- Energy Class
- Class C
- 120 Watt
- Diagonal Class
- 42"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- 99 cm
- 12.2 cm
- 58.45 cm
- 23.6 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.4833mm x 0.4833mm
- Touchpoints Qty
- 10
- Response Time
- 9 ms
- Colour Temperature Control
- Infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Remote Control
- Remote control
Audio System
- Audio Controls
- Balance, bass, treble
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Speakers
- 2 x speaker - 12 Watt
- Connector Type
- VGA input , DVI-D input , HDMI input , Serial output , Composite video input , S-Video input , Audio input , 2 x audio input , Component video input , Speakers output , Serial input , USB , VGA output , Composite video output , Audio output , LAN
- Pen stylus
- Cables Included
- VGA cable , DVI cable , USB cable
- Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
