iiyama ProLite TH4264MIS 42" 1920x1080 9ms VGA DVI HDMI Touchscreen IPS LED Large Format Display
Quicklinx: B1K7WS00 Mfr#: TH4264MIS-B1AG
  • 1080p
Incorporating the InfraRed 6 point touch feature along with the supreme panel color performance, this display offers the optimum performance for a truly multi-user interactive display experience. The Anti-Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. Landscape and Portrait friendly, the display can be mounted according to the application for true impact in Interactive Digital Signage and with protection glass the display can handle harshest environments from the classroom to public domain retail installation.
  • Touch technology - infrared
    This technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by a finger or stylus. This technology does not rely on an overlay or substrate to register a touch event, so it's impossible to physically "wear out" the touchscreen. The infrared technology ensures great picture performance. As there is no overlay or substrate on the screen the display characteristics remain virtually unaffected by the touch functionality.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Full HD
    With true 1920 x 1080p resolution this LFD is ready to display high definition images. This means it can accommodate more information on the screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • PIP (Picture in Picture) function
    PIP (Picture in Picture) function allows you to watch images coming from two different sources at the same time.
  • Light sensor
    The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for and increase or decrease in light.
  • Multiple inputs
    A wide range of video inputs assures compatibility with multiple platforms.
  • Key lock
    You can easily lock and unlock the controls preventing unauthorized changes to settings you made.
iiyama ProLite TH4264MIS-B1AG 42" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, pen stylus
Voltage
Energy Class
Class C
119 Watt
Power Consumption (On mode)
103.7 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
151 kWh
98.05 cm x 12.35 cm x 57 cm
22 kg
Energy Class
Class C
119 Watt
103.7 W
151 kWh
Diagonal Class
42"
Commercial Use
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
98.05 cm
12.35 cm
57 cm
22 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.4833mm x 0.4833mm
Response Time
9 ms
Display Menu Language
English, German, French, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Multitouch, infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
24 Watt
Speakers
2 x speaker - 12 Watt
Connector Type
VGA input , Composite video input , S-Video input , Composite video input , Audio line-in , DVI-D input , HDMI input , DisplayPort input , Audio input , Serial output , Audio output , VGA output , Composite video output , LAN , USB
Pen stylus
VGA cable , DVI cable , USB cable
DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Input Voltage
0.5 Watt
