Incorporating the InfraRed 6 point touch feature along with the supreme panel color performance, this display offers the optimum performance for a truly multi-user interactive display experience. The Anti-Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. Features include PIP and PBP perfect for video conferencing or handing multi-input content in many environments. Landscape and Portrait friendly, the display can be mounted according to the application for true impact in Interactive Digital Signage and with protection glass the display can handle harshest environments from the classroom to public domain retail installation.
Touch technology - infrared
This technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by a finger or stylus. This technology does not rely on an overlay or substrate to register a touch event, so it's impossible to physically "wear out" the touchscreen. The infrared technology ensures great picture performance. As there is no overlay or substrate on the screen the display characteristics remain virtually unaffected by the touch functionality. -
IPS technology
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Full HD
With true 1920 x 1080p resolution this LFD is ready to display high definition images. This means it can accommodate more information on the screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
PIP (Picture in Picture) function
PIP (Picture in Picture) function allows you to watch images coming from two different sources at the same time. -
Light sensor
The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for and increase or decrease in light. -
Multiple inputs
A wide range of video inputs assures compatibility with multiple platforms. -
Key lock
You can easily lock and unlock the controls preventing unauthorized changes to settings you made.
- iiyama ProLite TH4264MIS-B1AG 42" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, pen stylus
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 119 Watt
- Power Consumption (On mode)
- 103.7 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 151 kWh
- 98.05 cm x 12.35 cm x 57 cm
- 22 kg
- Product Type
- Energy Class
- Class C
- 119 Watt
- 103.7 W
- 151 kWh
- Diagonal Class
- 42"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- 98.05 cm
- 12.35 cm
- 57 cm
- 22 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.4833mm x 0.4833mm
- Response Time
- 9 ms
- Display Menu Language
- English, German, French, Polish, Russian, Spanish, Dutch
- Colour Temperature Control
- Multitouch, infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Speakers
- 2 x speaker - 12 Watt
- Connector Type
- VGA input , Composite video input , S-Video input , Composite video input , Audio line-in , DVI-D input , HDMI input , DisplayPort input , Audio input , Serial output , Audio output , VGA output , Composite video output , LAN , USB
- Pen stylus
- Cables Included
- VGA cable , DVI cable , USB cable
- DDC-2B, VESA DPMS, CB, TUV Bauart
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
