Capacitive touch technology
This technology uses a sensor grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when a human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with a human finger (also latex gloved) and a stylus pen. -
Open-frame LFD
Open-frame monitors are an ideal solution for kiosk integrators and in-store retail. -
24/7 operation
24/7 displays are designed for a continuous operation. -
Anti-Glare coating
The Anti-Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. -
Ball-drop-test-proof
The ball-drop-test uses a half-kilo steel ball, which is dropped onto the touch screen from a height of 1.3 meter. If the touch screen surface remains unaffected, the monitor passes the ball-drop-test for high impact resistance and durability.
- iiyama ProLite TF5538UHSC-B1AG 55" LED-backlit LCD display - 4K - for digital signage / interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen (multi touch)
- Diagonal Class
- 55"
- Commercial Use
- Yes - interactive digital signage
- Matte black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 60 Hz Frame Rate
- Video Interface
- HDMI
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Energy Class
- Class A
- 120 Watt
- Power Consumption (On mode)
- 120 W
- Power Consumption Stand by
- 1 Watt
- Dimensions (WxDxH) - without stand
- 129.45 cm x 6.8 cm x 76.5 cm
- 41 kg
- Product Type
- Energy Class
- Class A
- 120 Watt
- 120 W
- Diagonal Class
- 55"
- Commercial Use
- Combined With
- Touchscreen (multi touch)
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- PC Interface
- Modes
- Portrait mode, landscape mode, Face-up Mode
- Design
- Open Frame
- Dimensions
- Without stand
- 129.45 cm
- 6.8 cm
- 76.5 cm
- 41 kg
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 60 Hz Frame Rate
- LED backlight
- Image Contrast Ratio
- 1100:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 12
- Response Time
- 8 ms
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- Operation Hours / Days
- 24 / 7
- Palm Rejection, designed for 24/7 operation, ball drop test proof, scratch-resistant, edge-to-edge glass
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
Remote Control
- Remote control
- Projected capacitive touchscreen
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- VGA input , DisplayPort input , DVI-D input , 2 x HDMI input , Audio input , RS-232 input , LAN , Audio output , USB
- Batteries
- Cables Included
- USB cable , HDMI cable , DisplayPort cable , IR extender cable
- Plug and Play, DDC-2B, CB, cULus, TUV Bauart, CU, DisplayPort 1.2
- Power Device
- Power supply
- Input Voltage
- 1 Watt
- Width (Shipping)
- 140 cm
- Depth (Shipping)
- 24.5 cm
- Height (Shipping)
- 93 cm
- 0 °C
- 40 °C
