The Full HD Open Frame TF4338MSC is the ideal interactive display solution for education, kiosks, interactive digital signage and in-store communications. The Projective Capacitive (PCAP) touch technology with 12 touch points ensures a seamless and accurate touch response. Featuring a metal housing with 60950-1 ball-drop proof, scratch-resistant, edge-to-edge glass and an IPS panel; this display can be used in landscape, portrait and face-up orientation in the most demanding environments for maximum flexibility and accessibility.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen. -
Open frame
Open frame monitors are an ideal solution for kiosk integrators and instore retail. -
AG coating
The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks.
- iiyama ProLite TF4338MSC-B1AG 43" Class (42.5" viewable) LED-backlit LCD display - Full HD - for digital signage / interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen (multi touch)
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Commercial Use
- Yes - interactive digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, cable cover
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 75 Watt
- Dimensions (WxDxH) - without stand
- 98.75 cm x 6.8 cm x 58.77 cm
- 21.6 kg
- Product Type
- Energy Class
- Class A
- 75 Watt
- Diagonal Class
- 43"
- Diagonal Size
- 42.5"
- Commercial Use
- Combined With
- Touchscreen (multi touch)
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Modes
- Portrait mode, landscape mode, Face-up Mode
- Design
- Open Frame
- Dimensions
- Without stand
- 98.75 cm
- 6.8 cm
- 58.77 cm
- 21.6 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare, 7H Hard
- Image Contrast Ratio
- 1100:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 12
- Response Time
- 12 ms
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- Palm Rejection, Projected Capacitive Touch (PCT), designed for 24/7 operation, ball drop test proof
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
- Connector Type
- VGA input , DVI-D input , 2 x HDMI input , DisplayPort , Audio input , Audio output , LAN , RS-232C , USB
- Cable cover
- Cables Included
- HDMI cable , DisplayPort cable , USB cable , IR extender cable
- DDC-2B, VESA DPMS, CB, cULus, IP54, TUV Bauart, CU
- Power Device
- Power supply
- Input Voltage
