iiyama ProLite TF2415MC-B2 23.8" 1920x1080 16ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ2PWS00 Mfr#: TF2415MC-B2
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 16ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15), HDMI
£406.62 ex VAT
£487.94 inc VAT
The ProLite TF2415MC-B2 uses PCAP touch technology and is built into a bezel with an edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch resistance, making it perfect for kiosk and public high use facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation.
  • Capacitive touch technology
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex glove) and stylus pen.
  • Foam seal
    A foam seal finish around the monitor ensures seamless integration and optimal dust protection.
  • Through glass touch
    This through glass touch screen works right through glass and can turn glass surfaces into an interactive touch screen display. Use it on storefront windows, real estate office, in-store for POS or restaurants.
  • Anti-fingerprint coating
    This nano coating ensures a smoother touch and less resistance in the swipe. It makes the screen less static and susceptible to dirt, dust, fingerprints and it improves the clarity of the content displayed on the screen.
iiyama ProLite TF2415MC-B2 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/378595
Energy Class
Class F
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
21.7 W
Touch-screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
350 cd/m²
Contrast Ratio
3000:1
Response Time
16 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
7H Hard Coating
34.7 cm x 4.25 cm x 57.5 cm
5.8 kg
DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, CU
3-year warranty
Display Type
Energy Class
Class F
36 kWh
Diagonal Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
350 cd/m²
Brightness w/touchscreen
315 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
16 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
English, French, Italian, Spanish, Dutch, Japanese, Chinese
Edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology, landscape mode, portrait mode, Face Up mode
5.8 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DisplayPort , HDMI , USB , Audio line-out
Mechanical
VESA Mounting Interface
100 x 100 mm
Fingerprint-resistant coating, IP65 protection
Remote control
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
21.7 W
21.7 kWh/1000h
Power Consumption (Typical)
25 Watt
Included Software
Drivers & Utilities
Microsoft Windows CE, Linux, Apple MacOS X, Microsoft Windows Vista / XP, Microsoft Windows 7 / 8 / 10
Limited warranty - 3 years
Response Time: 16ms
Speakers: None
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: iiyama
