iiyama ProLite TF2234MC-B6X 22" 1920x1080 8ms HDMI VGA LED Monitor
Quicklinx: FH40WS00 Mfr#: TF2234MC-B6X
ProLite TF2234MC-B6X uses projective capacitive touch technology, built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for interactive digital signage.
  • Robust display technology
    Equipped with a 22-inch IPS LED-backlit LCD monitor, the iiyama ProLite TF2234MC-B6X delivers vibrant visuals and consistent colors from wide viewing angles of 178 degrees, ensuring an immersive viewing experience for all users.
  • Interactive touchscreen
    Featuring a 10-point multi-touch capability, this monitor allows for a highly responsive and interactive user experience, making it ideal for applications requiring gesture-based commands.
  • Durable and clear visuals
    The display is protected by a 7H Hard Coating, making it resistant to scratches and damage, while the Full HD 1080p resolution ensures crisp and clear images for all types of content.
  • Versatile connectivity
    With HDMI, VGA, and DisplayPort interfaces, the iiyama ProLite TF2234MC-B6X offers flexible connectivity options, making it easy to connect to a wide range of devices.
  • Designed for any environment
    Thanks to its open frame form factor and IP65 compliant front protection, this monitor is designed to withstand the rigors of public use, making it suitable for kiosks, information desks, and other interactive stations.
iiyama ProLite TF2234MC-B6X - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/380629
Energy Class
Class F
Power Consumption (On mode)
19 W
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
7H Hard Coating
Voltage
51.75 cm x 4.6 cm x 31.35 cm
4.4 kg
Plug and Play, VCCI, DDC-2B, cULus, TUV Bauart, IP65, CU, REACH SvHC
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
350 cd/m²
Brightness w/touchscreen
305 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 84 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
7H Hard Coating
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese
HighBrightness, HDCP, 10-point multi-touch, anti-fingerprint, landscape mode, portrait mode, Face Up mode
4.4 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DisplayPort , VGA , HDMI , USB
Mechanical
VESA Mounting Interface
100 x 100 mm
Landscape / portrait mounting, front IP65 protection
1 x HDMI cable - 1.8 m , 1 x display cable - 1.8 m , 1 x USB cable - 1.8 m
Mounting Kit
Included
Input Voltage
19 W
19 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
1 Watt
Power Consumption (Off Mode)
1 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
