iiyama ProLite TF2215MC-B2 21.5" 1920 x 1080 14ms HDMI VGA LED
Quicklinx: G50JWS00 Mfr#: TF2215MC-B2
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 14ms
Speakers: None
Interfaces: VGA (HD-15), DisplayPort, HDMI
13 In Stock
£364.07 ex VAT
£436.88 inc VAT
The ProLite TF2215MC-B2 uses PCAP touch technology and is built into an eye-catching bezel with edge-to-edge glass. Thanks to a glass overlay covering the screen and a rugged bezel, it guarantees high durability and scratch-resistance, making it perfect for kiosk and high use public facing applications. Equipped with a foam seal finish it supports seamless integration into kiosks and provides IP65 rating resulting in dust and water resistance from the front. Landscape, portrait and face-up orientation ensures flexible mounting possibilities in almost any installation. For ease of integration, the TF2215MC-B2 comes equipped with external mounting brackets making it an ideal solution for kiosk integrators, industrial environments, control rooms and interactive multimedia.
  • Touch through glass
    This through glass touch screen works right through glass and can turn glass surfaces into an interactive touch screen display. Use it on storefront windows, real estate office, in-store for POS or restaurants.
  • Touch technology - capacitive
    This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
  • Open frame brackets
    This open frame monitor comes equipped with external mounting brackets. It guarantees easy installation and makes it an ideal solution for kiosk integrators and Instore Retail.
  • Anti-fingerprint coating
    This special Nano coating ensures a smoother touch and less resistance in the swipe. It makes the screen less static and susceptible to dirt, dust, fingerprints and it improves the clarity of the content displayed on the screen.
iiyama ProLite TF2215MC-B2 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/378611
Energy Class
Class F
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
19 W
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Input Connectors
HDMI, VGA, DisplayPort
Voltage
52 cm x 4.25 cm x 31.5 cm
4.4 kg
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU, REACH SvHC
3-year warranty
Display Type
Energy Class
Class F
30 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
350 cd/m²
Brightness w/touchscreen
315 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 82 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
HDCP, OSD lock, anti-fingerprint, glove touch mode, landscape mode, portrait mode, Face Up mode
4.4 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , HDMI , DisplayPort , USB , Audio line-out
Mechanical
VESA Mounting Interface
100 x 100 mm
90% light transmittance
Remote control
1 x USB cable , 1 x HDMI cable , 1 x DisplayPort cable
Input Voltage
19 W
19 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption (Off Mode)
1.2 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
Diagonal Size: 22in
Response Time: 14ms
Speakers: None
Interfaces: DisplayPort
Interfaces: HDMI
Brand: iiyama
