iiyama ProLite TF1734MC-B6X  17" 1280x1024 5ms VGA HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ2KWS00 Mfr#: TF1734MC-B6X
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), HDMI, DisplayPort
£367.98 ex VAT
£441.57 inc VAT
The ProLite multi touchscreen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched.
  • Enhanced durability
    Equipped with a scratch-resistant surface and designed to withstand the rigors of daily use, this monitor is ideal for environments where durability is a must. The anti-fingerprint feature ensures the display remains clear and easy to read, even in high-touch scenarios.
  • Optimal viewing experience
    Featuring a 17-inch LED-backlit LCD display with a native resolution of 1280 x 1024, this monitor delivers crisp, clear images. The wide horizontal and vertical viewing angles of +85 / -85 degrees and +80 / -80 degrees, respectively, allow for flexible placement and viewing comfort. The inclusion of glove touch mode further enhances usability in various settings.
  • Seamless connectivity
    This monitor supports a range of input options including HDMI, VGA, and DisplayPort, making it easy to connect to a variety of devices. The inclusion of a USB interface adds to its versatility, allowing for easy integration with peripherals.
  • Efficient and eco-friendly
    With an energy class of Class E and a typical power consumption of just 13 W, this monitor is both energy-efficient and eco-friendly. The low power consumption in both on mode and standby mode ensures minimal energy waste.
iiyama ProLite TF1734MC-B6X - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/386176
Energy Class
Class E
Power Consumption (On mode)
12.7 W
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.264 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Black, matte
36.9 cm x 4.75 cm x 30.7 cm
3.6 kg
Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, CU, REACH SvHC
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
350 cd/m²
Brightness w/touchscreen
315 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
HDCP, OSD lock, HID Compliant, scratch-resistant, anti-fingerprint, glove touch mode
Black, matte
3.6 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
DisplayPort , VGA , USB , HDMI
Mechanical
VESA Mounting Interface
100 x 100 mm
90% light transmittance
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Mounting Kit
Included
12.7 W
12.7 kWh/1000h
Power Consumption (Typical)
13 Watt
Power Consumption Stand by
2 Watt
Power Consumption (Off Mode)
2 Watt
Included Software
Drivers & Utilities
Linux, Microsoft Windows
Limited warranty - 3 years
Diagonal Size: 17in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: iiyama
