The ProLite TF1534MC-B5X 15" multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. The screen is IP65 rated which means it is dust- and water-resistant from the front. For ease of installation in any environment the ProLite TF1534MC-B5X comes equipped with external mounting brackets making it an ideal solution for kiosk integrators and in-store retail.
Capacitive touch technology
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus pen. -
Open frame brackets
This open frame monitor comes equipped with external mounting brackets. It guarantees easy installation and makes it an ideal solution for kiosk integrators and in-store retail. -
IP65 rated
IP65 means that the monitor is protected to water splashes against the enclosure from any direction. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
- iiyama ProLite TF1534MC-B5X - LED monitor - 15"
- LED-backlit LCD monitor - 15" - touchscreen
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 370 cd/m²
- Contrast Ratio
- 700:1
- Response Time
- 8 ms
- Colour Support
- 16.2 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Screen Coating
- Matte
- Matte black
- 33.75 cm x 4.45 cm x 26.55 cm
- 2.7 kg
- Plug and Play, DDC-2B, CB, cULus, TUV Bauart, IP65, EAC
- Display Type
- Diagonal Size
- 15"
- Panel Type
- TN
- Aspect Ratio
- 4:3
- Native Resolution
- 1024 x 768
- Pixel Pitch
- 0.297 mm
- Brightness
- 370 cd/m²
- Brightness w/touchscreen
- 330 cd/m²
- Contrast Ratio
- 700:1
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 31 - 60 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Spanish, Japanese
- HDCP, Eco-Mode
- Matte black
- 2.7 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , DisplayPort , HDMI , USB
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- IP65 protection, 90% light transmittance
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Mounting Kit
- Included
- Voltage Required
- AC 120/230 V
- 9 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Driver
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
