This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen.
Touch technology - capacitive
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen. -
Open frame brackets
This open frame monitor comes equipped with external mounting brackets. It guarantees easy installation and makes it an ideal solution for kiosk integrators and Instore Retail. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
- iiyama ProLite TF1015MC-B1 - LED monitor - 10.1"
- LED-backlit LCD monitor - 10.1" - touchscreen
- Energy Class
- Class A
- Energy Consumption per Year
- 12 kWh
- Power Consumption (On mode)
- 8 W
- Touch-screen
- Panel Type
- VA
- Aspect Ratio
- 16:10
- Native Resolution
- 1280 x 800
- Pixel Pitch
- 0.1695 mm
- Brightness
- 500 cd/m²
- Contrast Ratio
- 1300:1
- Response Time
- 25 ms
- Colour Support
- 16.2 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Screen Coating
- 7H Hard Coating
- Black
- 21.225 cm x 3.94 cm x 25.58 cm
- 1.5 kg
- DDC-2B, VESA DPMS, CB, cULus, TUV Bauart, CU
- Display Type
- Energy Class
- Class A
- 12 kWh
- Diagonal Size
- 10.1"
- Panel Type
- VA
- Aspect Ratio
- 16:10
- Native Resolution
- 1280 x 800
- Pixel Pitch
- 0.1695 mm
- Brightness
- 500 cd/m²
- Brightness w/touchscreen
- 450 cd/m²
- Contrast Ratio
- 1300:1
- Colour Support
- Response Time
- 25 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 60 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 170
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- OSD Languages
- English, French, Italian, Spanish, Dutch, Japanese, Chinese
- Edge-to-edge glass, HID Compliant, scratch-resistant, Projected Capacitive Touch (P-CAP) technology, landscape mode, portrait mode, Face Up mode
- Black
- 1.5 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , DisplayPort , HDMI , USB , Audio line-out
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- IP65 protection
- Included Accessories
- Remote control
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable
- 8 W
- Power Consumption (Typical)
- 15 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows CE, Linux, Apple MacOS X, Microsoft Windows Vista / XP, Microsoft Windows 7 / 8 / 10
