iiyama ProLite T2736MSC-B1 27" 1920x1080 4ms DVI HDMI DisplayPort Touchscreen LED Monitor
Quicklinx: FJ31WS00 Mfr#: T2736MSC-B1
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£350.77 ex VAT
£420.92 inc VAT
With its high resolution and accurate projective capacitive technology, the ProLite T2736MSC delivers seamless and accurate touch response. The panel technology guarantees high performance with excellent color reproduction and high contrast, making it an excellent choice for a vast array of demanding interactive applications. The flexible stand can be positioned at several angles creating a comfortable and ergonomic user experience.
iiyama ProLite T2736MSC-B1 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27" - touchscreen
Energy Class
Class A
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28.3 W
Touch-screen, USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
65.95 cm x 22.05 cm x 44.4 cm
7.4 kg
Plug and Play, DDC-2B, TUV Bauart, ERP, CU
Display Type
Energy Class
Class A
41 kWh
28.3 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Brightness w/touchscreen
255 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Portuguese, Polish, Russian, Spanish, Dutch, Japanese
Eco-Mode, Advanced Contrast Ratio (ACR), edge-to-edge glass, blue light reduction, i-Style Color
7.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , HDMI , DisplayPort , Headphones , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , Audio line-in
Mechanical
Tilt
Tilt Angle
-3/+73
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), built-in adjustable tilt stand, 85% light transmittance
1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Security Slot Type
Kensington security slot
AC 100/240 V (50 Hz)
28 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
iiyama ProLite T2736MSC-B1 27 Bundle deal on iiyama ProLite T2736MSC-B1 27" 1920x1080 4ms DVI HDMI DisplayPort Touchscreen LED Monitor
£449.94
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
