iiyama ProLite T2252MTS-b5 LED Monitor 22" Touchscreen 1920x1080
Quicklinx: CS8SWS00 Mfr#: T2252MTS-B5
The T2252MTS lets you browse the web, email and draw while working on multiple screens, docking or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures. The multi touch is not only fast but also fun to work with. Multiple inputs (VGA/ HDMI/ DVI) are available for flexible connectivity along with USB for the touch Interface.
  • VESA mount
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
  • Touch technology - optical
    This technology uses cameras. A touch event is registered with great accuracy when light is blocked by a finger or stylus. It's the only touch technology that does not rely on an overlay or substrate to register a touch, so it's impossible to physically "wear out" the touchscreen. In fact you don't really have to physically touch the screen.
  • OverDrive feature
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • Advanced Contrast Ratio
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite T2252MTS-b5 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
20.2 W
Touch-screen, stylus
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
51.65 cm x 22.05 cm x 37.15 cm
5.7 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, VESA DPMS, TUV Bauart
Display Type
Energy Class
Class A
30 kWh
20.2 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Brightness w/touchscreen
220 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), i-Style Color
5.7 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen, stylus - touchscreen
Movement Detection Technology
Optical
VGA , DVI-D , HDMI (HDCP) , Headphones , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-3/+73
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
15 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
CS8S StarTech.com Articulating Monitor Arm In Stock £101.86
CS8S StarTech.com Dual Monitor Stand In Stock £69.36
CS8S StarTech.com Cubicle Monitor Hanger In Stock £45.29
CS8S StarTech.com TV/Monitor Arm - Wallmount In Stock £59.78
