The ProLite T2252MTS is a 22" two-point multi-touch monitor based on the Optical Touch Screen technology with a 1920 x 1080 high definition LCD screen.
It has outstanding features i.e. 1000:1 contrast ratio, 260 cd/m2 brightness and 2 ms response time. Moreover, the T2252MTS is Windows 7 Compatible and ready for the emerging business and consumer software packages. The multi touch function is supported only under Windows 7. The monitor lets you browse the web, email and draw while working on multiple screens, docking or typing on the on-screen keyboard. You can scroll and rotate pictures, draw, zoom in and out using certain tap, flick, grab and pincer gestures. The multi-touch is not only fast but also fun to work with. HDMI, DVI and analog inputs are available for flexible connectivity, along with USB for the touch interface.
X Res
A typical LCD uses four backlight lamps. By reducing this number to two only, Iiyama has managed not only to considerably lower the power consumption, but also to reduce the CO2 emission into the environment making this LCD a true ECO-Friendly product. -
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. -
ACR (Advanced Contrast Ratio)
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
HDMI (High-Definition Multimedia Interface)
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
OverDrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
- iiyama ProLite T2252MTS-3 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22" - touchscreen
- Energy Class
- Class A
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 20.2 W
- Touch-screen
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.65 cm x 24 cm x 37.75 cm
- 5.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC-2B, VESA DPMS, GOST-R, TUV Bauart
- Display Type
- Energy Class
- Class A
- 30 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour balance, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), single touch: XP/Vista, multi touch: Windows 7/8 (HID)
- Black
- 5.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Optical
- VGA , DVI-D , HDMI (HDCP) , Headphones , USB
Mechanical
- Tilt
- Tilt Angle
- -9/+22
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, stylus
- Cables Included
- 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 20.2 W
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
Sustainability Information
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
