ProLite T2234MSC uses Projective Capacitive Touch technology, built into an eye catching bezel with edge to edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for interactive digital signage. In addition to the superb image quality, the screen is suitable for demanding environments. It is dust and water resistant from the front. The ProLite T2234MSC is the ideal solution for interactive digital signage, instore retail, kiosks, gaming and interactive presentations.
Touch technology
This technology uses a sensor-grid of micro-fine wires integrated into the glass that covers the screen. Touch is detected because electrical characteristics of the sensor grid change when human finger is placed on the glass. Thanks to the glass overlay this technology is highly durable, and the touch function remains unaffected even if the glass is scratched. It offers perfect picture performance and will work with human finger (also latex gloved) and stylus-pen. -
IPS
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Scratch resistance
Scratch resistance is essential for touch solutions used in public places and schools. This is achieved thanks to a glass overlay covering the screen. It guarantees high durability of the touch function and even more importantly the touch function remains unaffected even if the glass is scratched.
- iiyama ProLite T2234MSC-B5X - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22" - touchscreen
- Energy Class
- Class B
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 21 W
- Touch-screen
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.247 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- 7H Hard Coating
- Voltage
- DC 12 V
- Black
- 51.75 cm x 21.9 cm x 35.15 cm
- 7.2 kg
- VCCI, DDC-2B, VESA DPMS, cULus, TUV Bauart, IP65, CU
- Display Type
- Energy Class
- Class B
- 31 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.247 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 225 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 8 ms
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 31.5 - 82.3 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- HDCP, scratch-resistant, Projected Capacitive Touch (P-CAP) technology
- Black
- 51.75 cm x 21.9 cm x 35.15 cm - with stand
- 7.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , DisplayPort , USB , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable ¦ 1 x DisplayPort cable ¦ 1 x USB cable ¦ 1 x audio cable
- Input Voltage
- DC 12 V
- 21 W
- Power Consumption (Typical)
- 21 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 95/98, Microsoft Windows CE, Linux, Apple MacOS X, Microsoft Windows Vista / XP, Microsoft Windows 7 / 8 / 10
