iiyama ProLite T2234MSC-B3X 22" 1920 x 1080 8ms VGA DVI Monitor
Quicklinx: CW45WS00 Mfr#: T2234MSC-B3X
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£413.92 ex VAT
£496.70 inc VAT
ProLite T2234MSC uses Projective Capacitive Touch Technology, built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive digital signage. In addition to the superb Full HD image quality, the screen is suitable for demanding environments. It comes with a rugged bezel, which means it is dust and water resistant.
iiyama ProLite T2234MSC-B3X - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22" - touchscreen
Touch-screen
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.247 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
6H Hard Coating
51.75 cm x 21.9 cm x 35.15 cm
7.2 kg
Environmental Standards
TCO Certified
VCCI, DDC-2B, VESA DPMS, cULus, TUV Bauart, IP65, CU
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.247 mm
Brightness
250 cd/m²
Brightness w/touchscreen
220 cd/m²
Contrast Ratio
1000:1
Colour Support
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 82.3 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
6H Hard Coating
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
HDCP, Projected Capacitive Touch (P-CAP) technology
51.75 cm x 21.9 cm x 35.15 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , DVI-D (HDCP) , USB , Headphones
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable , 1 x audio cable
27 Watt
Linux, Microsoft Windows 7 / 8 / 10
iiyama ProLite T2234MSC-B3X 22 Bundle deal on iiyama ProLite T2234MSC-B3X 22" 1920 x 1080 8ms VGA DVI Monitor
£513.09
Diagonal Size: 22in
Response Time: 8ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
