ProLite T2234MSC uses Projective Capacitive Touch Technology, built into an eye catching bezel with edge-to-edge glass. Featuring IPS LCD screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect display for Interactive digital signage. In addition to the superb Full HD image quality, the screen is suitable for demanding environments. It comes with a rugged bezel, which means it is dust and water resistant.
- iiyama ProLite T2234MSC-B3X - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22" - touchscreen
- Touch-screen
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.247 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- 6H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.75 cm x 21.9 cm x 35.15 cm
- 7.2 kg
- VCCI, DDC-2B, VESA DPMS, cULus, TUV Bauart, IP65, CU
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.247 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 220 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 82.3 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 6H Hard Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
- HDCP, Projected Capacitive Touch (P-CAP) technology
- Black
- 51.75 cm x 21.9 cm x 35.15 cm - with stand
- 7.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , DVI-D (HDCP) , USB , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x USB cable , 1 x audio cable
- Input Voltage
- Power Consumption (Typical)
- 27 Watt
- OS Required
- Linux, Microsoft Windows 7 / 8 / 10
