ProLite T2234MC uses Projective Capacitive Touch Technology, built into an eye catching bezel with Edge to Edge glass. Featuring IPS LCD Screen technology, it offers exceptional color performance and wide viewing angles, making it a perfect interactive display for Interactive Digital Signage. In addition to the superb image quality, the screen comes with an IP54 Rating, making it dust and water resistant. It comes with a rugged bezel making it suitable for demanding environments. The screen also features a vast array of inputs including DVI as well as USB for the Touch sensor itself, and a High Definition 1920 x 1080 Resolution. The ProLite T2234MC is the ideal solution for Interactive Digital Signage, Instore Retail, Kiosks, Gaming and Interactive Presentations.
- iiyama ProLite T2234MC-B1X - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22" - touchscreen
- Touch-screen
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.247 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- 7H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.75 cm x 21.9 cm x 35.17 cm
- 7.2 kg
- VCCI, DDC-2B, IP54, TUV Bauart
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.247 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 225 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 31.5 - 82.3 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- 7H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, colour temperature, phase
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- 10-point multi-touch, Projected Capacitive Touch (PCT) technology
- Black
- 51.75 cm x 21.9 cm x 35.17 cm - with stand
- 7.2 kg
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- DVI-D , VGA , USB
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable , 1 x VGA cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 40 Watt
- Power Consumption Stand by
- 3 Watt
- Included Software
- Driver
- Dimensions & Weight Details
- With stand - width: 51.75 cm - depth: 21.9 cm - height: 35.17 cm - weight: 7.2 kg , Without stand - width: 51.75 cm - depth: 4.6 cm - height: 31.35 cm
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
