iiyama ProLite T1932MSC-B5X 19" 1280x1024 14ms HMDI VGA DP LED Monitor
Quicklinx: DRGPWS00 Mfr#: T1932MSC-B5X
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 14ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), HDMI, DisplayPort
£372.10 ex VAT
£446.52 inc VAT
The ProLite T1932MSC-B2X multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles.
  • Enhanced connectivity
    Equipped with HDMI, VGA, and DisplayPort interfaces, this monitor offers versatile connectivity options for a wide range of devices, ensuring seamless integration into any workspace.
  • Interactive touchscreen
    Featuring a 10-point multi-touch screen with projected capacitive technology, this monitor delivers a highly responsive and intuitive touch experience, perfect for interactive applications.
  • Superior image quality
    With a 19-inch IPS display that supports 16.7 million colors, this monitor provides vibrant image quality, excellent color accuracy, and wide viewing angles, making it suitable for both professional and personal use.
  • Ergonomic design
    The monitor's tilt adjustability, ranging from -5 to +90 degrees, offers ergonomic comfort for extended use, enhancing user productivity and experience.
  • Durable and secure
    Designed with edge-to-edge glass and a scratch-resistant surface, along with a Kensington security slot for theft protection, this monitor is built for durability and security in any environment.
iiyama ProLite T1932MSC-B5X - LED monitor - 19"
LED-backlit LCD monitor - 19" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/369770
Energy Class
Class E
Power Consumption (On mode)
14.2 W
Touch-screen
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.2928 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
43.2 cm x 21.9 cm x 39.1 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, CB, cULus, IP54, TUV Bauart, EAC, CU
Display Type
Energy Class
Class E
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.2928 mm
Brightness
250 cd/m²
Brightness w/touchscreen
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
14 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, edge-to-edge glass, scratch-resistant
6.9 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , HDMI , DisplayPort , Audio line-in , USB
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 90% light transmittance
1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Security Slot Type
Input Voltage
14.2 W
14.2 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Sustainability Information
ENERGY STAR Certified
Diagonal Size: 19in
Response Time: 14ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: iiyama
