The ProLite T1932MSC-B2X multi touch screen is based on projective capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The IPS matrix guarantees high performance with accurate and consistent color reproduction, and wide viewing angles.
Enhanced connectivity
Equipped with HDMI, VGA, and DisplayPort interfaces, this monitor offers versatile connectivity options for a wide range of devices, ensuring seamless integration into any workspace. -
Interactive touchscreen
Featuring a 10-point multi-touch screen with projected capacitive technology, this monitor delivers a highly responsive and intuitive touch experience, perfect for interactive applications. -
Superior image quality
With a 19-inch IPS display that supports 16.7 million colors, this monitor provides vibrant image quality, excellent color accuracy, and wide viewing angles, making it suitable for both professional and personal use. -
Ergonomic design
The monitor's tilt adjustability, ranging from -5 to +90 degrees, offers ergonomic comfort for extended use, enhancing user productivity and experience. -
Durable and secure
Designed with edge-to-edge glass and a scratch-resistant surface, along with a Kensington security slot for theft protection, this monitor is built for durability and security in any environment.
- iiyama ProLite T1932MSC-B5X - LED monitor - 19"
- LED-backlit LCD monitor - 19" - touchscreen
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/369770
- Energy Class
- Class E
- Power Consumption (On mode)
- 14.2 W
- Touch-screen
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.2928 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 14 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 43.2 cm x 21.9 cm x 39.1 cm
- 6.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC-2B, CB, cULus, IP54, TUV Bauart, EAC, CU
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 19"
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.2928 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 225 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 14 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 31 - 80 KHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Spanish, Japanese, Chinese
- Cable management cover, HDCP, edge-to-edge glass, scratch-resistant
- Black
- 6.9 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- VGA , HDMI , DisplayPort , Audio line-in , USB
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 90% light transmittance
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14.2 W
- Power Consumption SDR (On mode)
- 14.2 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
