ProLite T1931SR-W5 is based on 5 wire resistive touch technology. The price/performance ratio is ideal for the budget conscious user while quality and performance are certainly not compromised. The display inputs include both analog and digital with touchscreen connectivity via USB offering great flexibility. A solid and steady base supports the touchscreen with an adjustable stand offering full 90-degree angles. The ProLite T1931SR-W5 can be used in a variety of environments, especially recommended for shops, restaurants and industrial purposes.
Touch technology - resistive
5-wire resistive touchscreens are very durable and can be used in a variety of environments. They are especially recommended for shops, restaurants and industrial purposes. -
Integrated speakers
This LED monitor is equipped with two high-quality stereo speakers. -
LED backlit
Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true eco-friendly product.
- iiyama ProLite T1931SR-W5 - LED monitor - 19"
- LED-backlit LCD monitor - 19" - touchscreen
- Energy Class
- Class E
- Energy Consumption per Year
- 27 kWh
- Power Consumption (On mode)
- 14.2 W
- Touch-screen, stylus
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 43.2 cm x 21.8 cm x 39 cm
- 6.6 kg
- Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart
- Display Type
- Energy Class
- Class E
- 27 kWh
- Diagonal Size
- 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 200 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 31 - 80 KHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Spanish, Japanese, Chinese
- Cable management cover, HDCP, 5-Wire Resistive Touch Screen Technology
- White
- 6.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
Input
- Touch-screen, stylus - touchscreen
- Movement Detection Technology
- Resistive
- VGA , HDMI , DisplayPort , USB , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB cable , 1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14.2 W
- Power Consumption SDR (On mode)
- 14.2 kWh/1000h
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 2 Watt
- Included Software
- Drivers & Utilities
