Iiyama ProLite T1931SAW-1 LCD touchscreen monitor 9" / 1280 x 1024 - DVI-D, VGA in black with speakers
- iiyama ProLite T1931SAW-1 - LCD monitor - 19"
- LCD monitor - 19" - touchscreen
- Touch-screen, stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 230 cd/m²
- Contrast Ratio
- 900:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 43.2 cm x 39 cm x 21.8 cm
- 6.6 kg
- VCCI, DDC-2B, VESA DPMS, GOST-R, IP54, TUV Bauart
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 19"
- Built-in Devices
- Stereo speakers
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 230 cd/m²
- Contrast Ratio
- 900:1
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, input select, phase, H-size
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Japanese
- Black
- 6.6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Surface acoustic wave
- Serial , DVI-D , VGA , Audio line-in , USB
Mechanical
- Tilt
- Tilt Angle
- 95
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x serial cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by / Sleep
- 3 Watt
- Included Software
- Drivers & Utilities
