iiyama ProLite T1732MSC-B5X 17" 1280x1024 LED Monitor
Quicklinx: DKJJWS00 Mfr#: T1732MSC-B5X
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort, VGA (HD-15)
£329.26 ex VAT
£395.11 inc VAT
The ProLite T1732MSC-B5X 17" multi-touch screen is based on projected capacitive technology which thanks to a glass overlay covering the screen guarantees high durability, scratch-resistance and perfect picture performance. The touch function remains unaffected even if the glass is scratched. A solid and steady base supports the TouchScreen with an adjustable stand offering full 90 degree positioning angles. Menu Buttons are located on the side of the screen which can be locked to prevent tampering and includes a handy function to deactivate the TouchScreen for cleaning. In addition the edge-to-edge glass design creates an eye-catching finish with high light transmission guaranteeing perfect picture clarity and brilliant colours.
  • Enhanced visual clarity
    With a native resolution of 1280 x 1024 and LED backlight technology, this monitor delivers crisp, clear images and vibrant colors, making it ideal for both professional and personal use.
  • Interactive touchscreen
    Equipped with a 10-point multi-touch screen and projected capacitive movement detection technology, this monitor offers an intuitive and responsive interface for an enhanced user experience.
  • Versatile connectivity
    Featuring HDMI, VGA, and DisplayPort interfaces, along with USB and audio line-in ports, this monitor provides flexible connection options to a wide range of devices.
  • Ergonomic design
    The tilt adjustment feature allows users to find the perfect viewing angle, improving comfort during extended use.
  • Durable and user-friendly
    Designed with edge-to-edge glass, scratch-resistant surface, and glove touch mode, this monitor is built to withstand daily wear and tear while ensuring ease of use in various environments.
iiyama ProLite T1732MSC-B5X - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Energy Class
Class E
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
11.9 W
Touch-screen
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
38.7 cm x 20.2 cm x 34.2 cm
5.6 kg
Plug and Play, VCCI, GOST, DDC-2B, CB, IP54, TUV Bauart
Display Type
Energy Class
Class E
27 kWh
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Brightness w/touchscreen
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.4 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
Cable management cover, HDCP, edge-to-edge glass, OSD lock, scratch-resistant, glove touch mode
38.7 cm x 20.2 cm x 34.2 cm - with stand
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
VGA , HDMI , DisplayPort , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 90% light transmittance
USB cable , HDMI cable , Audio cable , DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
11.9 W
11.9 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
2 Watt
Included Software
Drivers & Utilities
Diagonal Size: 17in
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: VGA (HD-15)
Brand: iiyama
